some1 knocked my bike over while it was parked , now the electric's only work when i kick start it and the indy's flash fast and the rear ones dont work horn sounds weak aswell!!!!!!!!
Hi, Sounds like battery related issue, check your connetions to the battery and see if there is any wires earthing out at all! If the batterys earting out it will prevent a power going directly through the circuit and may be losing electricity due to this , zus not having enough to power the auto start and indicaters! I had the same problem on my cagiva and turned out the connetions to the battery where corodid up! Hope this helps
lol i fixed it 10 mins after i posted this thread , the fuse next to the battary had only 1 clip in...lmao
if the bikes been on its side, you may want to check the electrolyte level in the battery if its not a gel type, coz it'll have lost some out the overflow :thumbsup: top it up with some distilled water
