electrical problem
Discussion in 'The Workshop' started by boddy101, Feb 15, 2009.
  1. boddy101
    boddy101 New Member
    on my aerox everythings connected correctly exept the rear light which is connected to a live wire so its turns on when the ingnition gets turned on. but today i started my bike reved it and the headlight went white and blew then my sidelights wents followed by my speedo backing light. any ideas what could have caused this. they electrics havent worked right since i bought the bike
  2. wobbly_trials
    regulator/rectifier unit is fucked
  3. boddy101
    boddy101 New Member
    so it got nothing to do with the rear light being connected to the battery and the front light getting to much currunt
  4. wobbly_trials
    not unless you've got it all wired into a 24 volt battery.
  5. px166bajaj
    px166bajaj Active Member
    Fuck me Boddy, your Avatar must be ten feet tall! :msn1:
  6. boddy101
    boddy101 New Member
    yeah, didnt relaise it was gonna be that big removed it now
  7. MiNoR cOnFuSiOn
    why the hell is the rear light wired to the battery? fix ALL the bodgery first, then ask why things dont work. simple really
  8. boddy101
    boddy101 New Member
    i ran a wire from the live wire in the brake switch to the rear light so it lights up when you turn the ignition on. i can easily change it back if you think it would help
  9. MiNoR cOnFuSiOn
    yamaha think it would help... hence they made the wiring the way it is.. put it back. sort it out.
  10. boddy101
    boddy101 New Member
    yes sir. wobbly_trials dindnt think it would make a difference to the front lights.. this is where the fault is
  11. MiNoR cOnFuSiOn
    you bodged some wiring from the battery, somthing blew up.. wiring should stay as it is... i dont get why people play with it.
  12. boddy101
    boddy101 New Member
    thanks for your comment but if i had the back light connected properly the rear light would have also got fucked
  13. wobbly_trials
    re-wiring other parts won't help as it can put extra stress on other electrical parts.
    i would get your wiring sorted back to standard and try another reg/rec unit
  14. MiNoR cOnFuSiOn
    you know what, your too smart for your own good.. ask yourself this.. WHY the fuck is there a wire from your battery to your light??? if it didnt work befor then the same wiring has broken down further up the line... if it did work befor YOU have popped the rec... dont ask if your gonna argue the toss over some stupid wiring you bodged in..
  15. boddy101
    boddy101 New Member
    no my rear light is connected to a live wire coming from the brake switch and it works fine. but my front light is connected correctly and keeps blowing because i belive to much currunt is going to it. so 2moro im going to connect the rear light correctly buy new bulbs for the front and try it again if the bulbs blow again it must be the rectifier. thank you for your help MiNoR cOnFuSiOn you've helped me sooo much
  16. wobbly_trials
    the only thing that will blow it is voltage, not current.
    the only way the voltage can peak above 14v is if the reg/rec unit decides to go tits up.
  17. boddy101
    boddy101 New Member
    thanks i will try that 2moro
  18. MiNoR cOnFuSiOn
    no need to thank me...only tryin to help ;)
    but ye, wobbels sorted this one.. i was just winging about bodged wiring. fix it still m8, tis for the best
