Electric Start broke!!!
Discussion in 'The Workshop' started by Tam171190, Jul 3, 2007.
  1. Tam171190
    Tam171190 New Member
    Hi my electric start has stopped working after my belt snapped about 2 months ago. I have been using the kickstart. When i press on the electric start button it just spins around and does not engage. You can hear it turning and it is turning fast but it seems to be spinning on a plate or something? Sorry for the poor description but its the only way i can describe it.
    Cheers
    Tam
  2. skuzzy
    skuzzy New Member
    sounds to me like wen the belt snapped it hs broken the ratchet drive wheel that drives the engine wen tryin to start it
  3. tweak
    tweak Member
    It'll be the sprag clutch. Needs tiny 3 crucial springs and 3 rollers to function. When your belt snapped it probably knocked one out which means it won't bite and turn the motor. If you can disassemble the variator then try find the springs/rollers (needle in a haystack job), patiently/carefully rebuild the sprag clutch up and slide back onto the crank, then reassemble variator.
