dt125
Discussion in 'The Workshop' started by wheelieboy, Jan 17, 2008.
  1. wheelieboy
    wheelieboy New Member
    hi i have just brought an old dt125 lc and i put water in the rad and it just leaks threw..
    but it dont leak from the rad it leaks from down were the engine is??
    some one said radweld but i dont know if that would work??
    many thanks.
  2. Jamie
    water pump seals are gone by the sounds of it
  3. wheelieboy
    so radweld wont work..
    and were can i get some seals from asap???? and would it still ride even if they have gone..???
    ta
  4. Jamie
    sorry i dont know where you can get them from, but seriously do not ride it with no water pump seals.
    no water will be circulated and it wont last a mile
    have you checked the whole coolant system to make sure it isnt leaking from somewhere else and then running down to the engine bit?
  5. wheelieboy
    yeh i have its definatly come out from there!!
    i need to get one asap
    :w00t:
  6. wheelieboy
    but the thing i dont get is that it has a radiator on the side.....
    got a k&n air filter and it has a coolant bottle underneath the seat..
    soo..???
  7. wheelieboy
    think pro seal will work or were i can get it from??
  8. kyle1b1
    stop with the bodges !!!
    FFS just find the leak and fix :bird: :pimp:
  9. wheelieboy
    lmfao!!!
    :bird:
    well i need to know how to fix the fucking thing first!! :bird: :rant:
  10. kyle1b1
    well find the leak. where it is leaking make it stop leaking.
    fixed :bird: :pimp:
  11. wheelieboy
    :bird: well..
    how do i fix the leak when i have found the thing???
    smart arse! :bird:
  12. alexsr70
    alexsr70 New Member
    "Scootershack"
    big hint there SCOOTER, loooooool erm have you ever worked on an engine before? if you have to ask how to do it, then no offence but it might be worth taking it to a garage
  13. kyle1b1
    well if it is a gasket replace it. if a component has a hole in it replace it.
    if the cap aint on the header tank then shoot yourself !
    just see whats leaking first then report back to base.
    just make sure it aint leaking from somewhere else and running down.
