so i installed a 70 cc malossi sport kit and started to have problems...for one very low idle when i start it i have to blip the throttle a few times to keep it going but once warmed up all is well...then we go onto the second problem the damn idle again after a ride when i come to a stop the idle will hang but will go if i blip the throttle any idears as this is doing my dam nut in thanks
maybe you're idle is too low? there is a screw to change the amount of idle rev try adjusting it then testing it?
sorry to say mate the idle screw has nothing to do with my hanging idle if i turn the idle screw up more the idle hangs alot higher anyways i think ive found the problem thanks for your input anyway fella
turned out my a/f was well off i tryed the 38 pilot jet then the 40 nothing so went back down to 35 adjusted the a/f right this time and there we go all fixed
