Drivebelt too tight?
Discussion in 'The Workshop' started by kylespeedfight, Nov 7, 2011.
  1. kylespeedfight
    kylespeedfight Active Member
    New Gilera Runner 70
    my speedfight is having trouble turning over. The belt is stupidly tight, it used to be fine until i replaced the front pulley :glare: anyone know how to loosen the belt maybe? :lol: or what i could do to stop the belt being so tight? Really annoying. Thanks for any help
  2. stkflote
    stkflote Member
    zip 2t cat
    is your clutch working, you should be able to pull belt into clutch while fitting it ,sounds like your contra
    spring might to soft, or the torque driver under contra spring is stuck take clutch apart and pull it apart grease the torque driver pins and shaft
  3. FLENG2008
    FLENG2008 Member
    04 vx 125
    yer you cant adjust the belt
    try stripping it down and rebuilding it
    you may find you put a washer in the wrong place or something simple
