drive belt query
Discussion in 'The Workshop' started by foster, Dec 19, 2007.
  1. foster
    foster New Member
    does it cause i problem if i was to fit a smaller drive belt to my engine? i bought i new one and it happens to be about 1.5 inchs shorter than the original
    bearing in mind the one i had on previously has been riden for 4k miles, so it may of stretched a bit.
    the original has a product number of 436864
    while the new one has a number of 828223
  2. capri dave
    capri dave Active Member
    yes it would matter....fit the correct length ;)
  3. foster
    foster New Member
    ah why cudnt you of said no it doesnt lol. cheers
  4. frazer
    frazer New Member
    what does fitting a malossi belt compared with the standred belt do
    (sorry for hi-jacking this tread but thort it would be easier.
  5. MiNoR cOnFuSiOn
    diff angle to suite the malossi ramp.. only slight but usually a little wider
  6. frazer
    frazer New Member
    does it have any advantages over a normal belt
  7. MiNoR cOnFuSiOn
    longer gearing at any point as the belts thicker.. means more top end with a little accell loss.. rolerd up right you get an extra 1-2mph without any losses but your better off using it with a malossi variator as it wears qucik on a stock item
  8. frazer
    frazer New Member
    is it hard to swap variators
