Dossing about with admission pipes.......
Discussion in 'The Workshop' started by turbovetto, Apr 3, 2014.
  1. turbovetto
    turbovetto Well-Known Member
    tweaked ovetto
    I was faffing with the admission tonight so I took a couple of pics. I've just gone from a home made admission pipe to one which holds the carb at a less severe angle. I'm trying to get smoother running at low engine speeds. I suspect the angle of the carb is to blame for this - but there may be other factors. Only one way to find out....
    Here is the actual admission in my scoot :
    https://www.flickr.com/photos/116877957@N08/13610383554/
    Hemets/shopping are out ! I cut out the bottom of the bucket. I did the same for my gf's scoot - but I made a fibreglass bottom inside first - so she has a removable bucket-bottom. She can empty the contents of her handbag in there- but I can get at the carb without taking the whole scooter to pieces. I urge anyone with a Nitro/Ovetto/Mach G to do likewise !
    The green bit of plastic under the collar is not pretty - but it stops the jubilee clip cutting into the rubber pipe.
    There is a 5° plate under the reed box from RSE racing - The carb is mounted frontal - so there is a bit of the frame missing that holds the seat box on. This has been strengthened with the U shaped threaded rod you see.
    Carb is an OKO 21 - but it will take a 28 or a 28 Del Orto VHST for nuttier configs. The connecting tube is a fibreglass home made construction - made to be as big as is actually possible. The theory is - if the diameter is big - the engine just 'sees' it as a part of the air box and not a longer admission tract. This would appear to be true - because (jetting aside) there is no significant difference using the open filter - or this. The purple connector adds a nice venturi at the mouth of the carb - and is flexible - but air-tight. It is in fact the front shock dust protector from a trail bike - cut down.
    The intake is made so it will take a stage 6 big filter.
    The pipe is an after-market second hand experiment. I like the angle of the carb. I don't like the lack of venturi. And it's not straight like the home made version.
    This is the air box. It has been 'doctored' so it fits intake pipe.
    https://www.flickr.com/photos/116877957@N08/13610014893/
    It has a 23 mm intake hole. The entire thing is air-tight - but I added a big clip just to make absolutely sure.
    This is the home made intake pipe:
    https://www.flickr.com/photos/116877957@N08/13610032693/
    It is fugly on the outside.....
    https://www.flickr.com/photos/116877957@N08/13610022283/
    but there are interesting things going on inside....... The final approach has been sculpted so it narrows - and re-directs things straight into the reed box. It works stupidly well if you mash the throttle - but does not want to know if you open 1/4 - it just splutters. The hypothesis is that the carb is at 45° and just dumps petrol into the admission. I might be wrong - hence the expoeriment. It could be that the venturi is just too pronounced. We will see.
    https://www.flickr.com/photos/116877957@N08/13610370304/
    here is the other end. It is flat. My welding bent the plate - so we had to quiksteel it & then surface that flat. This is without doubt the best admission pipe I have if you just want to burn off. Better than the Stage 6 - better than anything I have tried. But not if you want 'normal' behavior. Only full-tilt boogie will work. Reed box is Malossi VL14 with several flavours of reed. Thick ones for the big boys (MHR team 2 or Metrakit pro race), Thinner Malossi for the Stage 6 Sport Pro.
    This may give someone some ideas. The other advantage is - any air box/filter makes noise. If you put it under the seat - you get less noise. And your wet-weather open-filter problems are gone.
  2. hairyjim
    Got a gilera ice
    Well there's a solution to my carb mounting problem and reed block dilemma for vision.if i do a copy..ile use alot of heat sinks on the parts that get welded.think a narrower one might help with port velocities. Looks good though..
    maybe it would help if you did alot of spot welds and joined the dots..less heat build up.
    turbovetto likes this.
  3. turbovetto
    tweaked ovetto
    Well I went on a run today with the big boys. Scoot was great- but I suspect it would have been even better with my home made pipe. Interestingly, there was no difference with the carb at a less steep angle. If anything it was worse. So I need to devote attention to the slow jet. I suspect it's too small and this is the cause of the splutter at 1/4 slow roll on. If you mash it it just flies.
