Doppler Fitted, New Rollers fitted.......
Discussion in 'The Workshop' started by JamesNRG, Jan 22, 2010.
  1. JamesNRG
    JamesNRG New Member
    Piaggio NRG Extreme
    Okay then, i ordered some 5.3gr rollers last night, they came this morning, well chuffed!!!
    RIght, i fitted the pipe, fitted the rollers and went out for a ride, the bike had very little acceleration then hit a power band and flew to 40, with a big grin on my face i carried on riding :grin:
    The bike then started to slow down, then wouldnt pull away at all,. wouldnt go past 10mph, god knows what this was?
    Will i need to Upjet a little or do i need some lighter rollers?
    Thankyee.
    P.S
    Bike: Piaggio NRG Extreme 2003
    A/C
    Pipe: Doppler S3R
    Rollers: Polini 5.3gr 19*15.5
  2. bertie
    bertie Active Member
    '93 Skipper LX125
    Try lighter rollers maybe 4.5g or so. Also need tighter clutch springs and yes upjet to around 60-65.
  3. JamesNRG
    JamesNRG New Member
    Piaggio NRG Extreme
    Okay thanks, Sounds like it could be a pain, when i get back ill make a video on how it goes, Its okay when ridden for a few minutes (round the block) then its just gutless... Dunno why? Standard pipe is the way forward atm lmao :yahoo:
  4. rideorcollide
    rideorcollide Active Member
    TYPH 172
    yeah still needs lighter rollers, thats why i said you should buy the stage6 box for 15.. comes with loads of different sizes
  5. JamesNRG
    JamesNRG New Member
    Piaggio NRG Extreme
    Cba to order off eBay and wait a week for delivery, i need it for sixth form etc, what size you reccomend now then?
  6. rideorcollide
    TYPH 172
    get 2 more sets if you can.. like 5g and 4g, then if the 5gs are too heavy and the 4gs are too light then you can use 3 of each and make some 4.5s, or use some of the 5.3s or something, but 2 more sets should give you enough different weights to get it right :)
  7. MiNoR cOnFuSiOn
    id say around 4.7 on this off the top of my head, but get a few sets.. always come in usefull (good to have LOTS of diff weight rollers lying about)
  8. JamesNRG
    JamesNRG New Member
    Piaggio NRG Extreme
    Thanks for your replys,
    Yeah ill order some 4.7's in a second, I'll make a video showing what it does when it is first started and what it does when rode for a few minutes
    Fine when first rode
    Powerless when rode for few mins
  9. JamesNRG
    JamesNRG New Member
    Piaggio NRG Extreme
    Right then, Ordered some 4.7's just now, if its still the same, whats the next step please? :amen:
  10. MiNoR cOnFuSiOn
    clutch spring set and a box of jets... you want from 60 up to the 80's jet wise (6mm dellorto jets) and the malossi/polini 3 pack of springs.
  11. JamesNRG
    JamesNRG New Member
    Piaggio NRG Extreme
    How much are Springs? and how do you fit them? do you need to adjust them or are the pre adjusted?
    EDIT: Found them on tinternet, they're about a tenner, but does the clutch need adjusting after they are done? how they fitted etc?
  12. rideorcollide
    TYPH 172
    you just remove the old ones and put them in... they are very stiff though so might wanna buy a spring puller tool or have some GOOD long nose pliers there..
  13. UK247
    UK247 New Member
    Any news on fixing this problem mate? I've got the EXACT same problem, just wanted to see what/if you had cured it and how? Cheers.
  14. JamesNRG
    JamesNRG New Member
    Piaggio NRG Extreme
    Sorry for late reply mate!
    Sadly i haven't.
    I've got a little stressed and confused with it now :rant:
    I'm gonna wait til' i got some more money and chuck in into a garage and buy a Leo Vince TT. Tell them to fit Clutch Springs, rollers correct jets etc as i haven't the slightest clue of what i'm doing, and don't wanna fook my bike right up :wave:
    If i was you, do the same, as it will end in tears :cry:
  15. MiNoR cOnFuSiOn
    where abouts are you?
  16. UK247
    UK247 New Member
    I think I have found the solution - to my problem anyway, yours may differ slightly. I've had my dad's mate who is a qualified mechanic look at my ped and he seems to know his stuff. He thinks its a fuel related problem.
    Basically my ped has been stood for well over a year by the previous owner. It still has the original fuel in from over a year ago, I.E The ped was not drained of fuel before it was put into storage - fuel has probably gone off/bad. I'm going to drain my tank and clean out my carb this week and see if this cures it. I'll report any change later in the week. If yours has been stood for any length of time I would advise you to do the same. Hope you get it sorted mate.
    :grin:
  17. rideorcollide
    TYPH 172
    its the ROLLERS!
  18. adz452
    adz452 Member
    Vespa T5
    na jamel i think its the rollers
  19. JamesNRG
    JamesNRG New Member
    Piaggio NRG Extreme
    Kent, South East London
  20. MiNoR cOnFuSiOn
    kent is not south east london.... behave
    what part of the county of kent do you live?
