hi guys just bought a rear disc set up for my typhoon and realise the typhoon top panel doesn't fit with the resevoir. What I want to know is does an l/c nrg top panel fit on no messing?
Hi, i don't think it doe's but you could use a slave cylinder like the one used on the front brake setup. That's how i did it on my typhoon, cheap enough off ebay , just fit it next to the front slave cylinder and "T" in to the brake fluid resevoir.
You could do what Marsh says otherwise to fit an NRG panel like on the newer models of typhoons you need the handlebar panel and inner handlebar panel and the clocks and any switches if yours aren't new shape switches. Or you could chop a big hole in your handlebar panel.
