do it need to take my clutch off to change the belt??
Discussion in 'The Workshop' started by p166y123, Feb 12, 2011.
  1. p166y123
    p166y123 New Member
    aerox
    right my aerox is being a peice on shit and i think the belt is slipping so gunna change it and its sppluttering when starting now could this be spark plug or battary?? really no pulling well
    regard andrew
  2. moonhead911
    moonhead911 New Member
    yes u need to remover the clutch
  3. YogiAerox0393
    YogiAerox0393 New Member
    Aerox!
    i've managed to change my belts on my aerox with out removing the clutch, just removed the variator and squeeze the torque drive so that the belt isn't being squeezed in then you be able to just slip it off :)
  4. p166y123
    p166y123 New Member
    aerox
    alright cheers guys
  5. gkcharr
    gkcharr New Member
    Unlikely belt slipping, but you dont need to remove clutch. but if you check belt for wear change rollers in variator as they may have flat spots you need to remove variator to install belt, put a new plug in and change air filter.
  6. p166y123
    p166y123 New Member
    aerox
    think its the belt cuz its got brand new rollers in and spark plug in the post
