hi servicing my WK zs125 bike but can’t find an oil filter? There does not appear to be any cylinder pod filter and I can’t see where a thimble filter may be? The drain plug has a magnetic tip which had signs of metal filings so oil change is essential. Do all bikes have oil filters or might it just not have one?
No but I think I’ve worked it out. It looks similar to a cg125 where you remove the whole clutch cover and a small flat filter sits at the bottom in a feed section. Means draining the cooling system to disconnect the water pipes first which I’ve only just flushed and refilled but that’s life.
