different stators causing misfire?
Discussion in 'The Workshop' started by kylespeedfight, May 5, 2011.
  1. kylespeedfight
    kylespeedfight Active Member
    New Gilera Runner 70
    on my speedfight im meant to have just a 3 wire stator that has 8 coils. When i swapped my bottom end it came with a 4 wire stator with 6 coils from a very early speedfight. Could this be causing my ped to misfire, as when running it goes pop pop pop, blows air out the exhaust and dies. Thanks to anyone who can help :)
  2. narato92
    narato92 Member
    Aprilia SR 125 99"
    Depends, are they compatible? How did you connect 4 wires into 3 plugs?
  3. kylespeedfight
    i didnt, 3 wires are plugged in but one isnt
  4. narato92
    narato92 Member
    Aprilia SR 125 99"
    I think that you connected them by colors. Good way to check their target by comparing where they go on both coils.
    For me it sounds like shaft position sensor fault. Maybe bell don't fit to this coil?
  5. kylespeedfight
    its a whole speedfight 1 bottom end and the engine wiring loom is different to the speedfight 2
  6. m1ck_t
    m1ck_t Moderator Staff Member
    alot of shit
    swap stators?
  7. kylespeedfight
    im gonna try that :)
  8. kylespeedfight
    im going to order a speedy 2 stator off ebay, but will there be a difference between a 50cc stator and a 100cc stator? they look exactly the same :confused:
  9. RIGZ.172
    RIGZ.172 Member
    camel
    there will be difference the 100cc stator may be a little bit bigger just buy the right one for your bike then it wont keep givin up on you lol
