difference between a 180 variator
Discussion in 'Maxiscooter Tuning' started by jj180, Nov 25, 2007.
  1. jj180
    jj180 Active Member
    Mrt 183/Vespa 300
    at the mo in my 172 ferom a 125 runner im running 172 25ml carb with a 105 jet, polini angled inlet and malossi reeds with a pm59 exhaust, the rest is standard, i have a few parts just havent bothered fitting them yet, just wodnering what the difference between a 125 variator and a 180 is, im thinking of fitting my 180 variator but id like to know the advantages/disadvanages, also could someone pelase tell me what rollers to run if possible please
  2. nrgandy
    nrgandy New Member
    im sure you need bigger rollers and aparently the 180 is suposed to bit nearly as good as malossi but wait untill someone who knows exactly like minor
  3. MiNoR cOnFuSiOn
    ramp is slightly diff and you can use 125 rolers with a 125 belt or 180 with a 180 belt.. depends what your setup requires. i find responce is better with them tho
  4. hotwot
    hotwot New Member
    So a 180 variator is good but the malossi is better?
    With the malossi vario do you run the 180 or 125 belt?
  5. italjohn
    italjohn Member
    Any one try this new variator? Art.-No.: P241608
    SR125-150 - Gilera Runner 125-180 - Italjet Dragster 125-180 Piaggio Hexagon 125-180/SKR 2t
    The old one you could set up like a 125 og 180, just by adding a spacer. Product Nr.: P241608
  6. hotwot
    hotwot New Member
    How could using a spacer set up the variator for a 125 or 180?
  7. MiNoR cOnFuSiOn
    thinner or thicker for whatever belt/rollers.. playing with the spacer has great results if you know what your doing
  8. italjohn
    italjohn Member
    Here is some pictures of this washer.
  9. MiNoR cOnFuSiOn
    ;) can run both or none depending on the belt and rollers used. im not letting off any secrets here but the thickness of shims on the back of the variator can have incredible effect.. the front spacing is simply to make sure the belt sits straight to the front pulley of the clutch.. belt MUST run completly straight to not wear out quick, kill power and not kill your crank.
  10. Biggie
    Biggie New Member
    Got these two variators...im guessing one is 180(left) and one is 125(right) as i saw a variator come straight off a 180 and it had the plate on the back..
  11. monty9120
    monty9120 Active Member
    Vespa gts300
    the one on the left with the screws is a 125 one. the one without is a 180 one on the right
  12. Biggie
    Biggie New Member
    Are you sure?
    I thought it was other way round, cos all my 125's have had the vario's without the back plate??
  13. Jefr0-180
    Jefr0-180 Active Member
    My previous 2 180s had the variator without the screws and they were 100% original before I took them into my hands ;)
