Derestrition help???
Discussion in 'General Scooter Discussion' started by Jimel smith, Mar 28, 2013.
  1. Jimel smith
    Jimel smith Member
    Aprilia sr 50 r 2005
    How to make a adly silverfox 50 go faster it goes 35 mph its my mates so whats the best way cheap?
  2. Iggy13
    Iggy13 Member
    The main restrictor will more than likely be in the variator, the centre bush/spacer might be the type with the restricted washer as part of it. So you might have to get it machined off or find a suitable replacement.
    The Cdi might also be restricted.
    Start with these things then go on further to the exhaust ect..
    Adly likes this.
  3. Mark Emerson Trentham
    Check exhaust for restricting bungs (usually spot welded)-"judicious"use of hammer chisel :).,restrictor ring in variator,upjet carb+new air filter to start.
  4. LukeD
    LukeD ZIp-Zippity Zip
    Piaggio Zip 50
    Variator will have a restrictor ring in, and most likely the cdi will need to be de-restricted too.
    Once you have done these it should go a little faster but to find real gains i would suggest a decent sports exhaust and upjet the carb.
  5. Mark Emerson Trentham
    Once you've your few basics together,might want to do a little reserch
    on rollers/variator to suit which performance range your aiming for.
  6. LukeD
    Piaggio Zip 50
    Setting a bike up after de-restricting is painstakingly difficult and expensive, so only de-restrict it if your friend has the funds to do so, and dont think the cheap parts are any cop either because you will be wasting your time,
    if your friend wants a decent gain in speed heres what i suggest he buys:
    Sports exhaust
    Upjet the carb
    Sports/racing variator and rollers
  7. Mark Emerson Trentham
    Ditto,when i uprate to a more modern 'ped;that'll be my 1st port of call!
    Always smart of course to have your workshop manual,and with research-
    asking arround make myself aware of uk compliance/restrictions'an especially
    and any spanners thrown in the works 'cause of chinese market regs.(noting-
    if restrictions/done with subtle variances).
  8. Adly
    Adly New Member
    Adly Citybird
    Cheers, as soon as I read this I realised that maybe I thought the centre bush looked longer than expected but info on my CityBird seems lacking on google.. i've got a Performance Variator off flea bay coming Wednesday (latest)... Newly modified exhaust before Friday (fingers crossed) :)
