Just recently fitted a 21mm dellorto carb to the speedfight and it kept falling out of the manifold (Enki manifold 36mm adapter) After tightening it up I've split the rubber manifold and need to know if the carb is the right sort for my bike. From reading online there are two different types of dellorto phbg, ones with a male outlet and ones with a female outlet. I think I've got the one with the female outlet and need to know is there a way I can fit this to the Enki manifold or should I just buy a new carb that will definitely fit the manifold? This is similar to mine, minus the clamp: Also if I order a new carb, what size manifold adapter should I buy? The adapters are on pedstop. Thanks.
