Ok i have a black edition 21mm dellorto phbg. The two grey pipes that hang down from the float chamber near the top were the throttle cable goes in. What are these, ive been told their oil feed lines, ive also been told there vaccume, and overflow. Ive searched the web but cant find any pictures or info for that. I gues their oil feed and ive got to put my pump lines on one and block up the other but putting superglue in a spare bit of pipeing then putting the other end of it over the attackemnt? Thanks
iv got my 21mm dell in my hand and as far as i know there over flow as oil feed is the little tiny niple snitcking out on the carb? i dont know but thts wt im thinking
im preaty sure the ones faceing down are fuel over flow and the lil tiny one is oil and one nearest inlet is fuel vacume and other is fuel.
so from the picture, the silver ones are overflow, and wont draw in extra air so dont need to be blocked, up, the one lablled vaccume is actually the oil feed and should be blocked up or connected. And the one lablled fuel is acutally fuel? thanks
on any carb the silver pipe fittings are overflows and the brass/gold ones are fuel vacume and oil... fuel is biggest oil is smnallest leaving vacume
so what one is the oil, as fuel is labbeld correctly, so is vaccume and oil lines aint fitting on their for shit
oil feed is what you have labbled as the throttle stop screw . its not a screw its a brass niple and your stop screw is on the other side wich is also known as the idle screw if im right
