Deffo a Speedsh*te
Discussion in 'General Scooter Discussion' started by Cockers, Mar 7, 2013.
  1. Cockers
    Cockers I hate speedfights
    well the speedfight earned its name the speedshite today! after being a pain in the arse on the way to college it decided to not start at all after college, phone was justa bout flat so couldnt ring to find out about my breakdown cover - resulted in a 12 mile + hilly push home! looking at it someones kicked my back panels in and it may have knacked the ignition coil, unsure.
    It would turn and turn and turn but would not fire, there is fuel getting to the carb and through it, When i took the air box there seemed to be a vapor pouring out of the carb not sure what that is!
    It did attempt to run for a few seconds but died with a bang which led to all of the pretty girls at college looking and laughing ( lucky I'm proper sexy so it doesn't really matter ;) )
    Im puzzled frustrated and a little broken any help is much appreciated
    cheers
  2. huff_diggler
    huff_diggler I'm ya daddy....
    Z550 Dr600 Cz250
    Any damage to the coil?
  3. Cockers
    dosen't seem to be on the out side but not been able to test it yet, our relationship is on hold because I'm ready to solve the problem with a fiver of fuel and a match!
    I'd love to say I only pushed it home from college to save fuel because I'm tight fisted and wanted to save petrol but sadly that is not the case
  4. Cockers
    also how would i test ignition coil with multi meter just a resistance and continuity test? cheers
    huff_diggler likes this.
  5. huff_diggler
    Z550 Dr600 Cz250
    Ok...is it possible the coil has packed up, does it spark? Cdi? Sounds ignition related, the vapour is unburnt petrol.
  6. Burridge
    MZ TS125 #swag
    The vapour is petrol due to it flooding from not firing up.
    Take the plug out, put it in the plug cap and rest it on some metal part on the bike and turn it over to see i your coil's working.
  7. huff_diggler
    Z550 Dr600 Cz250
    Ha ha haa, I suppose you can go down that road, can it take 10-20 thousand dc? Undo your spark plug, hold the plug near the head, press start button, see if it sparks :D if so, is it a nice bright purple/blue spark? Does it spark with every turn of the engine? If so, rule out ignition :D I know it's a bit old Skool , but hey, that just me ;)
  8. huff_diggler
    Z550 Dr600 Cz250
    Great minds eh?
    Burridge likes this.
  9. Cockers
    had a feeling it was petrol and was going to try he plug against zaust i promise! there is a spark there but it aint blue it looks quite weak!
  10. huff_diggler
    Z550 Dr600 Cz250
    Then my son, your first point of call is coil.
  11. Burridge
    MZ TS125 #swag
    The battery might be abit flat from turning it over alot, charge it, clean up your airbox of fuel then try again, if nothing then get a new coil, they're like, a tenner? :)
  12. Cockers
    for every few pushed of the button there was one light blue spark but the rest were quite weak! seen one on the net for about 20 quid so will order one with a new cap and a new plug!
  13. Cockers
    tell a lie its 13 quid!
  14. Burridge
    MZ TS125 #swag
    I'd go for a plug change before a new coil, knackered plugs can not spark well.
  15. Cockers
    priced up new plug, ht lead and coil and a cap, 25 quid incl postage! so will let ya know how they change the situation
  16. Cockers
    will order a plug now mate, cheers
  17. ramo
    ramo GoldMember
    Tried putting some premix straight into the cylinder and trying to turn it over like that?
  18. Cockers
    I have not mate I've left it for tonight, can't be arsed with it. I've fell out with it! haha will give it a try in the morning
    cheers
  19. Cockers
    Ordered some bits
    New float bowl I didn't crack the current one, promise
    New HT coil(incl ht lead)
    Plug cap
    And correct spark plug for my model(gap of 0.6mm according to my manual)
    so If I fit all of these and still having a problem that will rule out an ignition problem?
    cheers
  20. huff_diggler
    Z550 Dr600 Cz250
    next would be cdi I'm sure mate, do you get any voltage from the cdi? I'm sure tbh, it'll be coil or plug...
