decarbonizing tips
Discussion in 'General Scooter Discussion' started by phil.s, Apr 18, 2012.
  1. phil.s
    phil.s Active Member
    what are peaple using to clean built up carbon of the pistons and barrels im cleaning up a 50 barrel and the ports are full ive had a good look round the net for some tips and if there is any products around the home that might work and all i can find is wd40 and paint thinners.
  2. phil.s
    just a thought but what about alloy wheel cleaner ? my mate said oven cleaner which has costic soda but i think that will damage the barrel
  3. FiddyRox
    FiddyRox Well-Known Member
    Aerox, CRF450, YZ125
    I usually use clutch and brake cleaner and some 800 grit wet and dry on the piston
  4. phil.s
    the piston is gonna be easy to clean its mainly in the ports i need something i can spray in them leave it to soak then rinse out
