Hi, does anyone know if a 49cc Jonway Endurance (Shenke), can be de-restricted (the one pictured in my profile if it helps) Thanks in advance
the jonway endurance is the same as pulse scout I think.... if it is,just pull the pink wire out at the cdi. don't do any other derestriction method,your engine wont last as long.
Thank you, i'm not too fussed about it going much faster, would just like to pull up hills a little easier
once wire is pulled (don't cut because if police pull you and decide to look or your in a crash and insurance want tosee it you really can play dumb whereas you cant if you cut it) you should get another 3-4mph up hill,40mphish on flats.
It could have a spacer in the variator and possibly a restrictor in the carb top stopping the diaphram from opening fully!
