de-coking/cleaning 2 stroke exhaust
Discussion in 'The Workshop' started by bikerbeynard, Nov 23, 2012.
  1. bikerbeynard
    bikerbeynard Luke
    gpr 125 ,mbk rocket,
    I recently posted a video of my scooter on YouTube as I have still not sorted the jetting on my bike, and was looking for some more interesting help then "just go up or down a jet"or" fiddle with air mixture screw" when someone told me to clean my exhaust customers it seemed groggy, this sounds like a viable idea as I've been running m own premix petrol oil mix.was wondering if anyone had hard of this before
    Check the video if u want bye just typing in lukebeynon into you tube and find my channel
  2. Jonnymarrw00t
    Piaggio Zip 05 plate
    Very much doubt that'd build up that bad. Had a 10,000 mile cylinder kit and had like 1mm carbon in the exhaust port.
  3. scubabiker
    what oil do you use? if your using cheap shitty oil then yeah, ive seen exhaust ports nearly closed because of cheap oil. but if you use ttr or whatever its called now (is is called power 1?) well yeah any synthetic oil, should be ok
  4. astro77
    astro77 Active Member
    I use this fully synthetic, its about £12.50 from your local halfrauds [​IMG]
  5. scubabiker
    yeah thats the good stuff, well a747 is better but way more expensive!
  6. astro77
    what's a747:confused:
  7. scubabiker
    den er synthetisk castor olje, lukter godt men kosta massa penger!
  8. scubabiker
    i just wrote in norwegian didnt i... errrr.... its sythetic castor oil, it smells amazing but costs a lot. its really thick tho, like 75w oil almost
    xplicit vehicle and Todi-Corsa like this.
  9. astro77
    ah so better suited for premix, and yeah I love the smell of caster oil nothing else like it:)
  10. scubabiker
    i run it through my oil pump on my suzuki and its fine, you cant mix it with other oil tho, they separate and kinda go lumpy
  11. Jonnymarrw00t
    I run power 1 racing or strawberry two stroke (motocross oil) fully synthetic. But on a Sport kit just use semi synthetic.
  12. Stig
    Stig Well-Known Member
    EXUP1000
    ultimately, if you wanna decoke the pipe, remove it from the bike, take off the end can and stick a potato onto the end to make it water tight, tip it upside down and fill with hot water & caustic soda solution (can get crystals from wilkos or asda etc), leave it for a couple of hours checking regularly and it should be ok to clean out with water when done. Leaves it well clean..............
    astro77 and scubabiker like this.
  13. TGB-Tuning
    TGB-Tuning Gladiator 125cc
    Gladiator 125cc
    this is the one i get i pay £10
  14. scubabiker
    we sell it for 170NOK why is everything so much cheaper in england its crazy!
  15. TGB-Tuning
    Gladiator 125cc
    Yea but most parts are expensive in UK for most types of scooters
  16. scubabiker
    trust me, its not expensive, stuff over here is way overpriced, i guess the awesome wages kinda covers it tho
  17. astro77
    where are you mate:)
  18. scubabiker
    west coast of norway
  19. xplicit vehicle
    xplicit vehicle Member
    PGO Big Max 50
    do you have another exhaust to test on? cleaning exhaust is usually the absolute last thing to do. i thought my exhaust was clogged up too till i found out i had an air leak.
  20. A-LY
    A-LY Active Member
    get a blow torch onit, i decoked my suzuki pipe a while back and you could see the carbon being burned off
    scubabiker likes this.
