ive finally saved up and got myself a C16 but was wunderin out of the MHR REP , polini EVO 2 or polini EVO 3 which one i shud get i want the one with the most tunable power to go with the c16, 21mill etc cheers boys :good:
can run the rep on a c16 happily... the evo's do run well with them, but work better wiht a 20/21/30. the evo's DO need a full case flow/match to even work correctly tho and thats with a strong crank. best sticking with the rep. semi reliable good bolt on power and you can run the stock crank (providing its in good nick) and can be fitted wiht no case mods
yeah i red that the evos are better of with c20 etc but no centre stand so if i get the REP and run it in with the c16 and put a malossi crank in the mix with a 21 mill wat sort of power will i be looking at? also wat mill crank shud i get? because my stock crank is pretty much on the turn lol so will need a new one cheers :good:
you want a 40 stroke crank.. not a 44. its a 10mm pin on the mhr replica's.. only the evo crank/piston uses a 12mm pin. id go bgm crank c16 and rep for now.. should be over 10 horses easily. wont dissapoint ether way
