cylinder head
Discussion in 'The Workshop' started by aprilia123, May 22, 2008.
  1. aprilia123
    aprilia123 New Member
    i recently added a post about my cylinder threads on the head. the thing is the cylinder head threads are stripped a bit. my spark plug screws half in and wont come out but it wobbles. there is a good strong spark and good compression but the bike still wont start. does the spark plug have 2 be tightly in the cylinder head for it to start or is there a chance i can get it started? cheers
  2. SimonT
    SimonT New Member
    dude... dont try and start it if the plug is loose... if it does start, the plug my pop out.... like a ceramic projectile.....
    it probbly wont start if its not getting a good ground either....ie from the body of the plug through the thread to the head.
  3. younger-rider
    younger-rider New Member
    hhhmmm
    well basicly both threds are f**ked u have most probly put the spark plug in wonkie it most probz will need a new head and plug but if u just want to get it going now just do the plug up as much as u can so its well tight and u might av a chances :nerd:
  4. aprilia123
    the threads on the spark plug are intact and fine. im just dying to get back on the road just need some advice. cheers for help
  5. pow
    pow New Member
    A spark plug should never be done up to tight
  6. Sw1fT
    Sw1fT Active Member
    200SX S13
    a spark plug should never wobble :msn1:
  7. Aerox-lad
    Aerox-lad New Member
    just buy a new cylinder head wont cost much probs around £20.
  8. capri dave
    capri dave Active Member
    who the hells been servicing your bike....Edward scissor hands!!!
    if the spark plug isnt a nice snug fit the engine will never build enough compression,
    these things need to be corrected before you head out onto the road...
