cyclinder kits , what one
Discussion in 'Scooter Tuning' started by aerox crazy, Jan 24, 2010.
Thread Status:
Not open for further replies.
  1. aerox crazy
    aerox crazy New Member
    Hi i have a polini 70cc , cast iron kit , its about on its way out , and im feeling like buying a new kit.
    Am i rightto say the alluimi kits wear down quick, my aerox had a stage 6 one but the boy told me it weared down to quick and was unreablie, remember this is a road bike , school,collage if i get it, and just fun.
    Or should i go for a cast iron one again ? . If so should i pick the polini one , if i changed would it fook my settings ect. :cheers: , louis
  2. Ty70cc
    Ty70cc New Member
    Typh
    A good quality kit like the Malossi Mhr Rep (Alu) Or Polini (Alu) won't effect reliability and usually are more reliable standard bores if fitted properly to a well maintained ped. if your ped already has high milage you might want to consider looking at a new crank and bearings as well and a good service :)
    P.S Your Topic is in the Wrong Section
  3. aerox crazy
    Sorry for wrong section , still getting use to this forum
    So will the alluim one wear down quicker , even if looked after can it be honed , or bored out if needed , as i know the cast iron ones can be ?
  4. Stig
    Stig Well-Known Member
    EXUP1000
    why do you believe this ones on its way out?
    if you're even thinking of honing and boring an alu cylinder, then why not simply overbore the current one????????
  5. Saint Jonny
    Saint Jonny New Member
    the stage 6 kits are less reliable due to using a single ringed piston, aluminium isn't any less reliable as long as you use good oil with it
    and hows this topic in the wrong section
  6. Aerox-lad
    Aerox-lad New Member
    i have polini cast iron 70 on my rox. how long has yu're barrel been on that bike for. polini sports are good 70 kits. 2 ring piston so more reliablity. i bought my polini sport as i didnt want to change my carb and crank at the time and the polini sport isnt too overkill for the crank as it running what 5-6 bhp for me at the moment (bearing in mind standard carb :() if you want a reliable 70 stick with a 2 ring piston for sure . and cast iron is a good bet. just look after you're bike. this means servicing and using decent oils not that lawnmower sludge. you could try a malossi sport 70 aswell but stick wiht trusted names
  7. MiNoR cOnFuSiOn
    oh ffs how many times a week are we going to have this conversation??!??!!?!?
    most kits have dyno graph's you can look at.. every kit has been discussed to death on here.. just buy one.
Thread Status:
