hi guys i posted a while ago about this but when ive been riding along on my 70 aerox with bigger main jet and zx pipe if i hit a bump in the road it cuts out im sure its not my ht lead or plug so it must be something else but its becoming dangerous because i came to a busy roundabout yesterday and as i went over a little bump it cut out and i was stuck and it took a while to get her started again please help
is your stator wire coming loose? the one thats a crappy connector not a block mine did that last week when i went over a bump
how new is the 70 kit? whats the condition of the coil like ht lead, and cap too. also good point what he said ^ stator wires are only held in place with a little crappy piece of solder, a few years worth of jumps and its bound to degrade take your water pump off too and clean up all the connections as the oil pump is right by it too and if youve bled it in the past it attracts dirt and grime into that area which could have gotten near the stator wires etc..
bought from brand new and only done a thousand miles on it well run in ect nahh im 99% its something fuel wise because it sounds really choked as it comes back , if i hit a bump and it cuts and i rec it down the street it will start to work again but sounds choked to sh1t and after about 5 or 10 seconds picks up working again revving fine
