Cuts out after clutch lets go
Discussion in 'The Workshop' started by xenovia, Dec 23, 2007.
  1. xenovia
    xenovia New Member
    After a fairly long run at full throttle, when i slow down to stop, the clutch lets go and the revs drop very low- it usually cuts out. I'm not sure if this is an idle screw problem - because when i turn it on, it idles fine- it's only after a longish run that the revs will drop very low. Any ideas?
    Thanks.
  2. MiNoR cOnFuSiOn
    idle mix most probs.. set it up with the engine hot. choke compensates for it whren cold...
    try playing with the contra spring if the revs drop off too soon when decelerating
  3. wobbly_trials
    wind your tickover up a bit
    if it still does it, clean the pilot jet out.
  4. steve-k
    steve-k New Member
    im struggling with the same problem mate, i turned my tickover up quite a bit and it improved but only until it got more warm.
    is the contra spring the large spring which sits in between the clutch plates, i changed mine when i put the vari kit on, what shall i do with it?
    i now think it is the mixture screw as well but i still dont understand it lol
  5. MiNoR cOnFuSiOn
    ok, check your choke works correctly and set the idle mix screw to the position the manual states. now get it nice an warm
    then set the idle mix to the point it revs highest. this is usually about right. set the idle speed to an rpm that doesent die when you off the throttle at speed an it should be fine..
  6. steve-k
    steve-k New Member
    ok, checked my choke and its fine. the problem is i dont have the manual with the carb which tells me what the idle screw should be set at. can anyone please tell me, its a polini 21mm dellorto carb.!!?
    cheers minor by the way
  7. MiNoR cOnFuSiOn
    start from half a turn out from fully in.. might not start but its somwhere to try once warm....
    then snap the throttle open then closed quick and if it delays/lags wind it out a little but remember where it is. then fine tune till it runs smooth/doesent bog out and at the point it idles quiest neer this point when left alone...
  8. wobbly_trials
    i would tell you what mine is set at but i havn't got a clue, i can check tomorrow but i cant guarantee it will be the same for your bike
  9. steve-k
    steve-k New Member
    ok well im going to give that a go, only thing is i am currently waiting for a new starter switch pod because mine has broken, so the throttle isnt together :( real shit time for it to break as well, not happy.
    mind you i will give it a go when i get it going again.
    by the way, please find out wobbly as yours is same carb, but not same setup.
  10. wobbly_trials
    nah but its the closest setup on here i think
    what jet did you end up running?
  11. steve-k
    steve-k New Member
    its got a 72 in at the minute, ive got a 86 to put in so will be doing that this week. im going to do a sparkplug check when warm before anything though mate.
  12. MiNoR cOnFuSiOn
    jet makes fuck all diofference to idle mixture so will only affect starting at full throttle... can run without a jet if you dont rev it atall...
  13. wobbly_trials
    yeah, i was just curious.
