Create a Name on the Plastics?
Discussion in 'The Workshop' started by TGB-Tuning, Dec 3, 2012.
  1. TGB-Tuning
    TGB-Tuning Gladiator 125cc
    Gladiator 125cc
    Hi,
    Sorry for the Tittle but right now i have not other idea for it.
    Right basically i seen this project and i loved the idea of having something like this:
    On the moped's plastic and i am wondering which kind of tool or heated tool did we use for it.
    http://www.scootershack.co.uk/threads/bys-aerox-rossi-rox.2652/
    Thanks!
  2. tErr0
    Probably a mixture of a drill, saw and files. Could use a dremel too but it's easy to over cut.
  3. TGB-Tuning
    Gladiator 125cc
    Thankyou
  4. Stig
    Stig Well-Known Member
    EXUP1000
    as above for tools
    Mark out the basic outline and then remove the majority of material with a dremmel or simmlar...could use a pad saw with hacksaw blade in it..use a drill for a pilot hole to get the blade started. Finish edges by using fine metal files and eventually fine sand paper to remove the edges. Sharp scalpels are good for getting into the tight corners.
    If you need to cut down mudguards etc and need a straight line to finish, a block plane used for wood is ideal, and a spoke shave great for cleaning up curves
    TGB-Tuning and murerg like this.
  5. TGB-Tuning
    Gladiator 125cc
    Thankyou for the information. Will do what you said.
