Right so i recently got another problem... (Im seriously thinking of selling my bike because of all these problems im having.) This time my problem is that my indicators keep going mental when the engine is running but when its not and i only have the ignition on they flash correctly but i need to turn the switch off, on, off and on so either one to actual start flashing. (doesnt matter which sometimes the right works fine but i need to do the off on thing for the left and vice versa.) So what im thinking is that its the actual flasher unit. So do you guys think its a flasher unit or something else. (ive checked all the wires aswell they are all.
The problem could be your spark plug believe it or not! Make sure your running a resistor type plug for example: BR9es not B9es/ BR7hs not B7hs in other words make sure the plug has an "R" in the code.
