crankcase breathers? do they do anything?
Discussion in 'General Tuning' started by Mickey, Apr 28, 2013.
  1. Mickey
    Mickey Member
    Beeline 50cc 4t
  2. Mickey
    Mickey Member
    Beeline 50cc 4t
    this is how they work......
    Why do you need a crankcase breather? During the downward strokes of the piston inside the cylinder barrel pressure inside the crankcase can build up. This reduces performance, because the piston can no longer transfer its full force onto the crankshaft but also has to counteract the pressure in the crankcase.
    If the overpressure is released, the engine will rev more freely and can put more power onto the road. Furthermore, the dangerous effect of oil foaming can be prevented to the greatest possible extent so that the danger of the oil film tearing off can be drastically reduced. The same negative effect also occurs during the piston's up-stroke, except that it's a negative pressure that builds up and also has to be relieved. The kit simply replaces the stock oil filler plug.
  3. MARSH
    You already have a breather on the rocker box.
