crank splines damaged
Discussion in 'The Workshop' started by kylespeedfight, Apr 3, 2011.
  1. kylespeedfight
    kylespeedfight Active Member
    New Gilera Runner 70
    when my ped was running the front pulley fell off and obviously rubbed against the spinning crank. This completely rounded the pulley splines, so i got a new pulley and it will not slide on because the crank spplines are slightly worn. Will this mean i need to replace my crank? Thanks
  2. Admiwal Wabbit
    Admiwal Wabbit Member
    Or you can try file the splines with a very small file to try get the pulley to fit.
    but if you can afford to, then it's better to get a new crank as if they are worn they get more worn then you could end up with a crank thats no good anyway. may or may not happen.
  3. Gamble
    Gamble Member
    If you're in a position to, swap the crank. Seems like you've done a lot of work to your scoot so I'm guessing it's going to be kept for a while, always best to upgrade to prevent fault's than causing and fixing. :)
  4. kylespeedfight
    yeah i probably will change the crank, its just the messing about with taking the whole engine apart lol but ill give it a go :)
