Hi guys Stripped my typhoon 125 engine down and the con rod moves a bit side to side. Is this normal movement? Also does anyone have a 125 bore and piston oe either they want to sell? Cheers
side to side freeplay is fine as long as it's not excessive. Should not have any freeplay up and down though.
should move side to side a little its the up down movement that you need to worry about as stated above
