Crank bearings n seals helpp
Discussion in 'The Workshop' started by xREiS-, Dec 7, 2009.
  1. xREiS-
    xREiS- New Member
    Shitty Piaggio zip
    right ive decided whilst i wait for my other parts to get my aerox running im going to fit my crank bearings and seals. anybody got any tips on how to make this easier to do etc.. also i have seen it when peoples bearings are on the crank when they split the cases if this happens how do i get the bearings off the crank? any help appreciated :mrgreen:
  2. bait
    bait Active Member
    best use a new crank but if it happens get heat gun or blow torch and heat the bearings (not the crank) and they should loosen off then when fitting new bearings stick crank in freezer like a day before hand and then heat up cases agen with heat gun/blow torch till hot then press bearing in should push in easily if not something is wrong then heat bearings up and get crank out of the freezer and push it in to one half the cases then heat the other half and push it into that you can also fit the bearings to the crank first then the crank and bearings to cases and remember to make sure seals go into same depth they came out
  3. tErr0
    Er enough of the blow torch please. Can fuck up ali REALLY quick.
  4. m1ck_t
    m1ck_t Moderator Staff Member
    alot of shit
    lol, sooooooo true?
    ever tried to straighten a leaver? and give it just a touch too much? watch it drop like candle wax.
    heat gun works good, just take your time , dont rush things, and remember to make sure the crank spins nice and freewhen re-fitted. use the correct tools and grease/gasket goo
  5. MiNoR cOnFuSiOn
    gotta be quick enough that when the crank go;s in one side you can get it in the other while the bearing is hot/crank is cold so you can move the crank psition on BOTH bearings when its together (this is what hitting it at the end of a buidl does)
    put basicly.. look for the million and one threads where ive overly explained this.. or pay somone who knows what there doing to do it. first one usually go's wrong unless you have somone showing you.. took me a good few to get it right as i had to fumble mty way through and figure it out for myself.. not good as it ended up costing me hundreads in fucked unused cranks/bearings
  6. nrgandy
    nrgandy New Member
    i found when i first did it is speed and heat is the key you get these right and should go ok. i didnt heat the cases up enough one time so bearings didnt go in right but managed to jiggle it out and re freeze. freeze spray might be a good idea for a beginer
  7. MiNoR cOnFuSiOn
    or just beshown the first ime... keeps things safe.
  8. Stig
    Stig Well-Known Member
    EXUP1000
    IF you need to heat alu with a torch, rub some good old fashioned soap on the surface thats being heated...when it turns brown then the alu is at workable temperature...any further and it'll melt
    works every time :good:
  9. safekyle
    safekyle New Member
    Gilera runner 172
    Now that my friend is a brilliant tip.
    *puts that in my book* :amen:
  10. MiNoR cOnFuSiOn
    washing up liquid works better.. soap can somtimes not indicate/flow away befor it shows... burnt holes in thick ali using soap befor now... cheap yellow wasahing up liquid.
    or plain dont touch ali wiht a torch. can heat it to bendable temp with a heatgun in a FAR more controled temp (can also get cases hot enough to WARP wiht a heatgun)
    the problem wiht open flames is localized heat buildup.. its too much on too small an area, even if you work the torch it will still warp VERRY easily.
    buy a heatgun
  11. PrettyDodgyDave
    PrettyDodgyDave Member
    Runner 180
    blow torch does seem waaay to extreme
    ive put bearing in a case using a hairdryer (no im not lieing before anyone starts slating) and they went in pretty easily and the bike ran fine and stil does but ive got a heat gun now and yes its easier to warm up but gotta be very carful no to overheat/warp teh cases will try the fairy liquid next time i rebuild :good:
  12. bait
    bait Active Member
    ive used hair dryer for the bearings in the mounts on my sr and it works fine :)
  13. Runner-Joe
    Runner-Joe New Member
    Typh 125
    :whistle: :whistle: :whistle:
    didnt do any harm to mine, but i guess i have experience with them in my job lol
    (old seal was in there btw not new)
  14. Stig
    EXUP1000
    Minor, totally agree...it IS easier to use a hot gun. As for soap...I use the real thick bar...leaves a sludge coat on the surface...always works for me
    Agreed, about the torch too. I'd be using more of a blow lamp tho' with a much wider flame area on alu ...and not the welding torch, far too agressive
