Corsa Ring help
Discussion in 'Scooter Tuning' started by greg531, Jan 23, 2008.
  1. greg531
    greg531 Member
    I am putting my kit in and the piston will not go into the cylinder, does the chrome ring go on top or bottom ring slot?
  2. wobbly_trials
    top i do beleive. the rings should locate on pins in the grooves and compress in to nearly flush with the side of the piston, then you can slide the barrel on, using plenty of oil.
  3. MiNoR cOnFuSiOn
    rings are probably up side down.. theres a taperd side that fits the piston one way but not the other
  4. greg531
    greg531 Member
    Thanks, will try to turn them around and see if that helps....
  5. wobbly_trials
    fair point, didn't think of that one.
  6. greg531
    greg531 Member
    Turned it around, and got them in, thanks guys.......
