Guys I'm looking for a correct carb mount for my dellorto 25mm going onto my typhoon any ideas plus correct reed block
It has a 31mm connection at the manifold cos of the bigger body. You might be able to get away with squeezing it in the 125 size one but it doesnt last. Pm prostreet PHBL im using ATM..with a 28mm in it
I tried fitting a 25mm dellorto into a standard manifold, not a prayer. The original manifold is just too stiff to stretch.
I'm new to tuning may sound silly but you say same reed block ? Do you mean that there is one already fitted ? So just change the reeds to carbon ones thanks Simon
Yeah they're metal reed petals on the standard reed block. The last thing you want breaking and going into your engine! They're attached with screws into the reed block takes 5mins to swap them out
New 25mm rubber in let manifold on its way from psn . Do they come with gasket or do u need one when fitting
