Converting zip engines to wc.
Discussion in 'Scooter Tuning' started by Jonnymarrw00t, Jul 27, 2011.
  1. Jonnymarrw00t
    Piaggio Zip 05 plate
    Converting my ac cases to run Liquid cooled on a electric pump. Does anyone have any pictures of the piping roots to the pump and where too root the pipes from the pump to the kit ? And how do I wire the electric pump into the ignition.Also where is the best place to posistion the pump in the bike ? I've looked at Terro's bike but I can't quite figure out the rooting lol. Thanks. Sorry if I don't make any sence.
  2. Jonnymarrw00t
  3. m1ck_t
    m1ck_t Moderator Staff Member
    alot of shit
    Cant help you with pics of routing but i suppose if you look at it its just the most sensible way to do it ,theres no right and wrong, pump should be close to engine , and wire into any 12v switch live,so anything that goes live after the ignition is turned on , stay away from the cdi wires though.
  4. Jonnymarrw00t
    Thank-You m1ck t
  5. luke_2401
    luke_2401 New Member
    Under the footboard? As long as they arent kinked and are hidden well, just wang them where you like :)
    You could wire it into something like the rear light? Make sure you conect the negative to the frame though and NOT the negative from the light.
  6. Jonnymarrw00t
    I got told the best place to put it is into the ignition :)
