hi, i have a typhoon 125 engine, i want to convert it to liquid cooled for a project i am doing, i have split the cases, i am wondering what i have to do from there, also should i use a standard water pump or a electrical one, thanks
Just run the pipes and that to a electric pump. Put the lc kit on, All you'll need is rad/bottle/pipes/pump/elbow.
Do you need any water pipes going to the cases by the stator like on a liquid cooled engine, if you do how do you make one of them??
you can buy one of them metal pipes but you will have to drill a hole out for it as its blocked on ac
It isn't blocked on a ac. Had 5 engines in mine, None have been blocked. You can buy it all from www.pedparts.co.uk
