Connecting throttle cable on Typhoon 125
Discussion in 'The Workshop' started by Mehmet, Dec 18, 2008.
  1. Mehmet
    Mehmet Active Member
    AUDI A3
    Hi ... connecting the lower throttle cable....and the pin at the end of the cable it doesnt go through the metal hole at the top of the carb.
    Can anyone help please
    thanks
  2. nibbles
    nibbles Active Member
    wrong cable maybe u get iut made up or u buy it ?
  3. alexsr70
    alexsr70 New Member
    cables the wrong way round
  4. Mehmet
    AUDI A3
    no its the right way around.
  5. Mehmet
    AUDI A3
    it goes through....then when the metal top of the carb bents....it gets stuck because of the tip at the end not being able to go through.
  6. RY4N172
    RY4N172 New Member
    port it
  7. nibbles
    olololololol
  8. Mehmet
    AUDI A3
    FFS....someone please i really need this help.
  9. kyle1b1
    it cant be that hard man.
    go look at it and use your head.
    you know what the problem if. fix it
  10. MiNoR cOnFuSiOn
    hmm.... deffo a mikuni? (needle held in with screws?) and not a dell?
  11. Mehmet
    AUDI A3
    Kyle ... was there a reason for that comment...you think if i know why it wouldnt go though, id on be on asking for help?
    It goes in...but wont go through the bend !!!
  12. Jamie
    PUSH MEHMET PUSH!!!!!
    or tie some string around the end of it threat it through the bend and PULL MEHMET PULL!!!
  13. MiNoR cOnFuSiOn
    bend is a pain... lil bit of 3 in one, file the edges off the bottom of the pip (be fookin carefull tho as they are only weak and can come off easily...) then as sudgested just keep pushing.. dont rotate the cable atall tho and try not to bend it..
  14. Mehmet
    AUDI A3
    You dont know how much i have pushed....it just wont go through.
    That bit at the end just gets jammed.
  15. Mehmet
    AUDI A3
    Alright mate, ill try that tomorrow...Thanks for the help
  16. MiNoR cOnFuSiOn
    hang on a min... how long is that (in cm?)
  17. Mehmet
    AUDI A3
    Thats not my one dont worry lol
    Thats a 50 one
    Mine is a 125 orderd from shop with the part number provided thanks to terro
  18. kyle1b1
    you take you bend off and made sure noting inside it ?
    should go straight in
  19. Mehmet
    AUDI A3
    I put a stick through it to make sure its clear....and it is.... the end of the cable just seems too big and gets stuck.
    gona try file em down 2moro.
  20. Mehmet
    AUDI A3
    DADDY DIY F.T.W.
