compression
Discussion in 'General Scooter Discussion' started by andy_n, Aug 24, 2007.
  1. andy_n
    andy_n New Member
    hiya i put my bore kit on a thousand miles or so ago and its starting to feel sluggish and not alot of compression iv just ordered some mallosi rings and a gasket set should this get it abit better again im assueming its the rings or the barrel but im trying rings first
    probabaly becuse it didnt get a very good run in
    cheers
    Andy
  2. wobbly_trials
    or you may have cold seizes on the barrel if you ride it from cold.
    more than likely rings will improve it.
  3. andy_n
    andy_n New Member
    glad to here the rings could be the problem ill get em in when i get em and see what its like
    i assume im gunna have to start the run in all again ?
    how far again was it 500 miles or sumat daft ?
  4. andy_n
    andy_n New Member
    welli got a nice suprise whn i opened the engine up lol
    well i noticed abit of oil like underneith the manifold and thought nowt of it
    took the head off and found the seal had broken up and burnt oil and crap was leaking through a crack in the head really small like hole next to were the seal sits and the bolt goes on
    so the oil had run through the bolt hole and down the outside of the barrel
    felt the bearings and the top end i think its called onbetween the piston had abit of wobble went to ake it out to swap it and it had seized in the car that its on had like deformed :(
    i managed to get it out and replace it though
    i thought ok then so carried on stripping to find some scores in the barrel
    which turned out to be the pins that hold the rings in place had like come off the piston and rubbing on the barrel and one fell out when i rmoved the piston
    the bore kit had only done 1100 miles
    then to top it off the rings were the wrong size they were to thick
    but the originals were nt bad it was just losing compression through the leak
    all in all came out ok
