does anyone have a compression table for a nrg power dt ? i was sure there was one in my haynes manual but cant seem to find it
i need the psi rating for a compression tester but ive noticed some oil at the bottom of the barrel so i recon the base gasket has gone. its running fine but wont go above 30 unless on the flat or down hill and wont go past 7k so new gasket set and might aswell give it a new set of rings while im at it since the piston and rings in it have done 15k
you recon piston aswell as gaskets ? may aswell give it a new small end bearing aswell just need a torque wrench for doing the studs back up
yeh for a piston and ring kit its about £4 more than just 2 rings so might aswell get both and a new small end is only a few ££££ and then the gaskets to go with it all.
