Hi, I took some advice and instead of buying a new mallossi clutch i have been told to put some stronger clutch springs on the standard one? Is that correct advice? http://www.pedparts.co.uk/malossi-clutch-springs-1376-p.asp There are 3 colours - what colour is stronger? as there are 3 difference strengths... Cheers
I have used the polini clutch springs in the past, and you get instructions inside telling you what stiffness/strength the different colours are... if there are no instructions with the malossi springs, you can tell the strength by looking at the thickness of the springs...the thicker the coils the stiffer the spring
