Hi. I noticed recently that the clutch bell, when viewed from the top, the outer edge moves in and out by at least 2 mm. This is surely effecting balance. Currently I do have an issue after installing a malossi variator (with original rollers) that now has a rhythmic vibration at STEADY speeds of 120kmh and higher. My belt still looks good. I rotated the variator on the spines to correct imbalances, but that did nothing. Should I get the bell axis straightened? Can it be done? Any ideas on eliminating the vibration? Sent from my Samsung Note 3 with Tapatalk
There is a bit of a blueish tinge. The rollers went in correctly as I had both variators next to each other as I moved the rollers across. Sent from my Samsung Note 3 with Tapatalk
