cilender bolt snapped
Discussion in 'The Workshop' started by plebpl, Mar 31, 2009.
  1. plebpl
    plebpl New Member
    honda x8r-x
    title explains all really, basicly i just want to know if there is a way to get it out without drilling? its the thread that has come off im not able to grip anything around it.
  2. jayzee19
    jayzee19 Member
    you cand ry an extraction set where u drill a small hole that corresponds with whichever extractor tip u use. once u have drilled a smal hole tap the extractor tip in and then on the ed insert the 8mm nut adaptor and screw off. so it extends the bolt if you want. and if that dont work drilling and then retherad or drill bigger and use timeserts.
  3. plebpl
    plebpl New Member
    honda x8r-x
    okay mate ill give that a try :)
