chroming or and polishing
Discussion in 'The Workshop' started by pimped_aerox2, Sep 1, 2008.
  1. pimped_aerox2
    pimped_aerox2 New Member
    does anyone know where u can get chroming done cheap or of any home kits you can buy for a good price and also how sucessful polishing the engine casing would be etc.
  2. Saint Jonny
    Saint Jonny New Member
    polish your crankcase and laquer it, as it's aluminium so find a car wheel guide and follow that should do the trick. I'd like to get an exhaust chromed if i could
  3. RY4N172
    RY4N172 New Member
    a shop does polishing round here
    40quid for the transmission casing
  4. Saint Jonny
    Was watching Wheeler Dealers and they showed how to polish wheels, and they are the same thing really.
  5. billy #86
    billy #86 New Member
    wheeler dealers is the dogs :w00t:
  6. RY4N172
    RY4N172 New Member
    discovery turbo :hitit:
  7. m1ck_t
    m1ck_t Moderator Staff Member
    alot of shit
    :punk:
  8. MiNoR cOnFuSiOn
    polishing is easy and quick if you know how... the hard way is practiced by many.
    theres a few tricks. 1 of them is patience.. the ohter's you have to look at the guide as somone wrote one up ages ago.
    i use a totally diff method to polish than most hobbyists.. ill throw a project page up of my new engine tomorrow
  9. Jefr0-180
    Jefr0-180 Active Member
    Be good to see that minor.
    Polishing can come up like chrome and I had so many people thinking I hadn't polished it and I was lying to try and look good :confused:arc: lol.
    Just takes timeeeeeeeee
    Sure there is a couple of posts on this which shows how to polish.
  10. MiNoR cOnFuSiOn
    wont be finnished.. but will be a good idea of what a days work can do
  11. pimped_aerox2
    yeah i would like to see wat some good polishing looks like but how do u polish apart from loads of cleaning and bufing
  12. MiNoR cOnFuSiOn
    ok, put basicly... use a wire brush in a drill to remove loose metal/oxidising/roiad dirt.. then sand with 120 grit till its completly flat an theres NO black spots... (this is verry important) then 240 (at this stage i use a lubricant/fat) again till its flat and uniform, then buff with a rough mop and a soft compound then with hard.. its ALL in the first sanding so dont skip or try to rush it. you can get a mirror finnish but still be full of scratches and dimplels or you can polish till its an absoloutly liquid metal looking peice of mirror ali. its all about elbow grease especially hand sanding all the little places. the mop/buffer just polishes it up to give the shine, it should reflect by the time your done wiht the 240 if done right.
  13. WOLFFY
    WOLFFY New Member
    Nice one Minor :beer: :tup:
  14. MiNoR cOnFuSiOn
    this gives a good shine, for full on mirror go up through the grades.. up to 400 then 600 then a qucik hand blast wiht 1200.. remember lubricant is important wiht ali so lots of water/fat from 240 up or your wasting time.
  15. DYS VTR
    DYS VTR New Member
    skanky cRaKwhoR3s
    wot do u use just normal fat? :emb:
  16. MiNoR cOnFuSiOn
    tallo (renderd pig fat) or lard... talo (probably wrong spelling) is great stuff, once you use it you will never go back (cant belive the secrets i let off round here i tell ya) can get it anywhere that sels polishing compounds.. autosol works but is literally there to mantain a shine, i never really use it now as ive got mops galore.. everything up to gold grade
  17. DYS VTR
    DYS VTR New Member
    skanky cRaKwhoR3s
    nice 1, i thort u ment ordanairy lard from sainsburys :emb: :emb:
  18. WOLFFY
    WOLFFY New Member
    When you say you use fat, do you make sure there is no dust and literally just smear fat over it and rub it in till its all gone then carry on sanding? :wtf:
  19. MiNoR cOnFuSiOn
    you can use lard... just rub a smear onto the paper.. it will make ablack gunky mess on the paper and material.. dont remove it and remember even tho the paper is flat, coverd in grey fatty shit and starting to look shiny its stil working, use paper till its literally falling to peices.
    the fat stops you digging deeper and deeper and just makes a compound from the material youve removed mixing with the fat. your basicly using a compoiund and paper but the paper sets the grade of the compound produced by the fat and debris from sanding. dry paper removes too much and just takes fuckin ages
    try it with lard.. its 30p. do a section with and without and see what works. i already know you will be supprised what a bit of pig fat can do LOL
  20. DYS VTR
    DYS VTR New Member
    skanky cRaKwhoR3s
    im gonna do that tmoz, ill take a pic before i start and after a hour or so :pimp:
