CHOKE
Discussion in 'The Workshop' started by The General, Dec 16, 2007.
  1. The General
    The General Member
    Dellorto sent me a choke its like a black button with a gold screw/bolt going through it with a spring in the middle and a round bit at the bottom with a black thing inside. Yes I know its a bit descriptive ill try get a pic in a minute just need to know how to fit this its probably simple..
  2. capri dave
    capri dave Active Member
    :worthless:
  3. RY4N172
    RY4N172 New Member
    :worthless:
  4. The General
    The General Member
    anyone help?
  5. kyle1b1
    just screw it straight into carb. then you will pull the black bit or twist it or something.
  6. The General
    The General Member
    argh lol
  7. alexsr70
    alexsr70 New Member
    no, that choke screws directly into the carb.
    iv'e been trying to get one of these, where did you get it from btw?
  8. The General
    The General Member
    Go onto www.dellorto.co.uk
    Ring them up and just say you need the choke for whatever carb you need they ask your address and you just tell them your going to pay by paypal they tell you the direct amount to pay and they have it to you by the next day if you order before like 3pm
  9. The General
    The General Member
    Right I took this out in order to put the choke in the valve this was sat in. Before this had a screw screwed into (done by a friend) as I had no choke before.
    But after I removed this and tryed to put the choke into its place the choke doesnt fit in enough? I've tried screwing it right in so all the spring is compressed so I could just screw it in but it just doesnt go in far enough? What have I done wrong can someone help is there anything else I need to do.
  10. kyle1b1
    dosent need to be compressed. i think it should just like touch bottom when its uncompressed/choke off.
  11. The General
    The General Member
    yeh ok but then the bolts not far down enough for you to screw it into the carb if u know what i mean?
    :rtfm: argghhh lol
  12. The General
    The General Member
    anyone wanna help
