cheapest polini iron kit
Discussion in 'Scooter Tuning' started by yamaha1, Mar 31, 2008.
  1. yamaha1
    yamaha1 New Member
    hi guys wheres the cheapest place to get a polini iron kit form cheers tom also will a 21mm carb and 2extreme crank make this a good setup ?
  2. Dec
    Dec Active Member
    nothing ugm
    21mm carb is a gd idea but id go bgm pro evo crank with that setup not that theres anything wrong with a 2extreme crank but bgm jus seem to have a better reputation and theyre not alot more expensive if your on a budget
    dec
    and pm tuning are quite cheap 4 the polini kits ;)
  3. yamaha1
    yamaha1 New Member
    cheers mate with a new crank can you hold your ped flat out i had a malossi mhr rep kit untill i siezed it (rip) wiht a standard crank and that used to shake like hell when it got to higher revs and i just didnt want to keep it there :msn1:
  4. capri dave
    capri dave Active Member
    instead of BGM pro-evo...you could use the cheaper BGM-evo easily on a sport set up ;)
    its the crank im useing on my MHR-rep engine...seems more than up for the job!!!
    just out of interest the cheaper BGM-evo is the crank PM tuning rebadge as their own ;)
  5. yamaha1
    yamaha1 New Member
    cheers cap dave but the 2extreme ones are much cheaper and dont seem to have a bad write up
  6. capri dave
    just hope they are better than the 2extreme 70 kits :msn1:
    quite a few people had problems with them from off here in the past :wtf:
  7. Dec
    Dec Active Member
    nothing ugm
    i didnt :pimp:
    and my cranks running fine
  8. capri dave
    yeah but look at your sig :hitit:
    could of saved yourself a few bucks if you just bought a polini sport
    in the 1st place buddy ;)
  9. Dec
    Dec Active Member
    nothing ugm
    true true but at the time i didnt have the knowledge i have now and funds were limited
    believe me dave i wud love to start fresh on a stock engine but ill jus have to make do with what i have now
  10. alex_1966
    alex_1966 New Member
    get a polini evo 2 :punk:
  11. RY4N172
    RY4N172 New Member
    polini corsa FTW :punk:
