charging of the battery
Discussion in 'The Workshop' started by 04peajak, Aug 7, 2010.
  1. 04peajak
    04peajak New Member
    aerox
    hello, my battery doesnt seem to charge up and none of the electrics work when the engine is off or at idle, when the engine speed is slightly higher the alternator charges the electrical components which makes them work. Why will it not charge the battery? ive tried two different batteries with the same outcome
  2. jamesknowles1991
    jamesknowles1991 New Member
    gilrea runner 125 sp
    witch are they mf or not?? if not it mite need more deoinised water. also could do with fuse i have one next to my batt what that like
  3. nathan93
    Gilera Ice
    had same problem on my ice
    the battery was fucked
    1st try replacing the fuse then try another battery
  4. jamesknowles1991
    if it not an mf one it just need topping up but if is the like me and nath just said fuse new batt
    also u have the terminals nice and clean and attached properly make sure u have the rioght one where they should be
  5. GUNS
    GUNS the usual suspect
    racing SP70 & LX172
    if you can get a multi-tester, note resting voltage of battery, voltage drop when things are turned on, and voltage with engine running............. those three readings will tell you whats going on.
  6. 04peajak
    04peajak New Member
    aerox
    thanks everyone for your answers, i have tried two old batteries so ill try a new one, but what if it turns out the battery isnt the problem? What else could it be?
  7. m1ck_t
    m1ck_t Moderator Staff Member
    alot of shit
    regulator/rectifier or stator
