Changing key barrels !
Discussion in 'The Workshop' started by scorpio_-_kid, Jul 3, 2008.
  1. scorpio_-_kid
    scorpio_-_kid Member
    i want to change my key barrel for my gilera i wanted to kno if its real simple? how do i take out? or shud i jus barrel it out
    and fittin the new 1 jus push it in ? or is there sumthing to hold it in?
  2. jj180
    jj180 Active Member
    Mrt 183/Vespa 300
    remove the front inner panels and all you need to do this clocks and top panel will also help, then in the cylinder that the key barrel goes in to. on top is a small rectangle slot and if you push the key barrel slightly then you will see a small clip, removed this with a small electrical flathead, pull the barrel out swop from the on off lock part and reinsert and put hte clip back in job done. ope this helps and makes sense.
