changing clutch springs
Discussion in 'The Workshop' started by JogRguy, Mar 24, 2009.
  1. JogRguy
    JogRguy New Member
    whats the best way to change the clutch springs???
  2. CZYNRG
    CZYNRG New Member
    Impact gun, Long nose pliers, Strength
  3. BFC
    BFC New Member
    Just changed mine, read somewhere (may have been a post on here), dismantle the clutch assembly, screw the clutch to a work bench or similar. I tried with long nose plies but it was hard work, far easier to use a piece of string to stretch the springs. Once you've got it screwed down tight, put the string through the hook end of the spring so you can wrap the string around your hands a few times to get a good grip, simply pull on the string to stretch the spring sufficiently to either remove or re-fit, really easy to remove and re-fit springs this way, you can get much more leverage than you can with pliers.
  4. MiNoR cOnFuSiOn
    or search for all the other threads the same as this.. you will NEVER get blue/red springs in a 125 clutch, bearly get greens in there... strip the clutch, put the springs on the shoe's... put the shoes bit by bit on the pins wiht grips.. only way really..
    50's you can lever them on, but FUCK all that noncing about.. can get hardcore ring opening plires that make the job eaasy peasy but the easier it is the more likely you are to bend the springs.
  5. baz172
    baz172 Member
  6. MiNoR cOnFuSiOn
    considdering the blues are THICKER than the holes in the clutch i doubt this verry much.. you physically have to REAM the spring into place... unless your talking 50 clutches... at bare minimum the powdercote gets scrapped off the 125 springs befor they even go in the hole
  7. tErr0
  8. Vesta
    Vesta New Member
    What you on about circlips terro? Is that only on 125's? i never seen circlips on mine o_O
  9. baz172
    baz172 Member
    dont get me wrong it wasnt easy to get them in a little encouragment with hammer was needed but it was done i promise only for me to change back to green springs cause the blues are a bit of a twat on the road
  10. MiNoR cOnFuSiOn
    so you recomend mangeling a spring in with a hammer? these hit 40,000rpm..... probably bent your backplate while fitting them this way aswell as the springs themselves.
