its a commen fault on neos's for the centre stand to break an its annoying as hell and seen other neos's with side stands but cant understand were it bolts on to any help?
I have a side stand on my yamaha aerox and i think they are very similar to the neos as said it is possibly under the left foot panel, thats also where it is on the aerox there is a small metal square sticking out with a hole in the middle where you can put the bolt for the side stand through... Hope i helped
yeah your earox is bassicly the same as mine but with a diff panels also looks better then the neos's cheers mate
the neos is simmilar to the aerox although the sidestands are completely different, if u put a aerox side stand on it it will bend the subframe , you need the side stand that bold and clamps around to two frame ploles, it will stick out just behind the batery on the left side of the bike , hope it helps , sip-scooter is the only place i have found that do a good double clamp sidestand , hope it helps
this is like the one you need http://www.scootershop.gr/product_info.php?manufacturers_id=32&products_id=1671 jsut to show you what it looks like
im in westmidlands mate but were the stand pole is theve turned to ovals so its gotta be a sidestand but cheers anyway mate
