Carb size
Discussion in 'General Scooter Discussion' started by haz_666, May 14, 2007.
  1. haz_666
    haz_666 Member
    When someone says 'I have a 22mm carb...' what does the size refer to???
    Cheers
  2. SR-STEF
    SR-STEF New Member
    the inside diameter of were the slide fits i think i maybe wrong but i thinks its that?
  3. haz_666
    haz_666 Member
    what....???? lol :confused:
  4. Hursty
    Hursty New Member
    simple tirms.. the thickness of the hole going through the carb :w00t: :w00t:
    ben.
  5. wobbly_trials
    it is the internal diameter of the carb where it connects to the manifold.
  6. MiNoR cOnFuSiOn
    it is actually the smallest diameter through the carb as the 13mm dell's are underbored 17.5's
  7. connor
    connor Active Member
    o all ways fort it was the length of it lol
  8. Kieran
    Kieran Active Member
    st
    That would be very small :confused:
  9. haz_666
    haz_666 Member
    rite so if i take the carb out of the manifold and measure the diameter of the hole in the carb then thats its size...??
    Cheers
  10. MiNoR cOnFuSiOn
    or just look at the number on the side
  11. haz_666
    haz_666 Member
    i had a brief look but cant find it... roughly wher will it be??
    Cheers
  12. MiNoR cOnFuSiOn
    well, on the side on a flat peice of the carb. mabey clean it and then look as its pritty visible.
  13. haz_666
    haz_666 Member
    would it be 12mm??? cos thats the only number i see
    Cheers
  14. capri dave
    capri dave Active Member
    it would be 12mm...thats one of the most common size carbs on a 50cc scooter :D
